Radiator For 1994 Ford Van
Old Jun 16, 2006 | 05:58 PM
ed2hess's Avatar
ed2hess
Is there a good place to get a radiator on-line. I have a 351 V8 Ford and was wanting to upgrade from a two row to a three row.
Old Jun 17, 2006 | 08:03 AM
subford's Avatar
subford
NAPA auto parts is about the only one that sells a good MODINE radiator.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=0
Item#: MO 2339
Price: $247.00
tax and shipping not included
Disclaimer: The stated price may vary from the in store price and may change at anytime.
Usually ships in 24 hours.
[img]../images/u_clear.gif[/img]
Attributes:
Comments: Dimpled tubes.
Core Size:19 1/4" x 25 3/4" x 1 1/2" (2 Row)
Inlet Connector Size:1 1/2" Right
Inlet Header Size:3" x 26 3/4"
Make:Ford
Oil Cooler:12"
Outlet Connector Size:1 3/4" Left
Outlet Header Size:3" x 26 3/4"
Type of Mount: Double Flange
Old Jun 17, 2006 | 01:17 PM
Dannym's Avatar
Dannym
http://www.partsamerica.com
The supplier for Western Auto.
Old Jun 17, 2006 | 01:29 PM
ed2hess's Avatar
ed2hess
Napa didn't have a three row...and neither does Auto Zone.
Old Jun 17, 2006 | 02:24 PM
subford's Avatar
subford
Try a MO 2354 at NAPA it is for a 460 but should mount and hook up OK.
All hose connection are the same and the Rad. Support should be the same.
Here is the one it calls for a two row and the three row side by side.
Old Jun 17, 2006 | 04:25 PM
rclarke's Avatar
rclarke
I had great service at radiators.com a couple of years ago.
Old Jun 17, 2006 | 07:09 PM
subford's Avatar
subford
Would think Napa would have the MO 2354 above.
Old Jun 18, 2006 | 10:56 AM
ed2hess's Avatar
ed2hess
Thanks very much this is very useful information Thanks again I plan to go to Napa this afternoon.
Old Jun 18, 2006 | 04:38 PM
ed2hess's Avatar
ed2hess
Well I found out that the 3 row radiator is $400 so that goes out of the picture. I have one of those fluid clutches/w spring and wonder if I put a solid fan in will I get better radiator cooling?
Old Jun 19, 2006 | 10:46 PM
steddy's Avatar
steddy
I'm pretty sure that's the job you need flare nut wrenches for, fyi.
Old Jun 20, 2006 | 06:22 PM
Clubwagon's Avatar
Clubwagon
I bought a standard replacement radiator from O'Rielly's for about $150 after the rad shop tried three times to fix a simple leak.
Steve
'95 Clubwagon XLT
Old Jun 20, 2006 | 07:31 PM
subford's Avatar
subford
Steve
'95 Clubwagon XLT
From NAPA is a the pass MODINE radiator that he wanted:
Item#: MO 2354
Price: $427.00
The one from O'Rielly's is not an OEM and is a two pass that is made in China.
O'Rielly sells the same one that Auto Zone and the rest of auto parts sell, NAPA is the only one that sells the OEM Radiator.
Old Jun 20, 2006 | 08:29 PM
Clubwagon's Avatar
Clubwagon
Yeah, its a two row, so was the OE and he said the $400 3 pass was out. What do you expect for $250 less?
ed2hess you are having cooling issues? The standard two pass radiator should be more than capable of cooling in most any conditions. Mine has no trouble towing across the deserts in the heat of the summer. If you have having cooling issues I doubt its the capacity of the radiator. Yours may need cleaning or you may have another problem.
Lots of things can effect cooling. I have seen water pumps with the vanes eroded away, the rad plugged with scale, t-stats that only open partway... even a malfunctioning EGR valve can cause it to run hotter than normal.
What kind of problems are you having?
Steve
'95 Clubwagon XLT
Old Jun 23, 2006 | 03:37 PM
ed2hess's Avatar
ed2hess
Steve
'95 Clubwagon XLT
When I pull our lawn trailer in hilly roads for 4 -5 miles the temperature gage goes up over center. I have had radiator rodded, new fan clutch, and the
thermo stat is out. When I pull off the road the thing seems to cool down in a resonable amount of time. I just took it to trans shop to ensure that it is okay and not slipping. Today at 55mph that stupid fan clutch started making a lot of noise like a 747. It normally only does that when you first start out and essentially stops when I get to around 20 mph. I shifted into overdrive and back out and it seemed to settle down. Hope some of this makes sense.
Old Jun 23, 2006 | 03:54 PM
Clubwagon's Avatar
Clubwagon
Sounds like you have some kind of cooling issue. My '95 5 liter tows my racecar/trailer combo for hundreds of miles across the south in the extreme of summer heat and never gets much past the O in normal on the gauge. Even sitting in stop and go traffic when towing through construction zones or Atlanta, no issues. And that is running the dual air all the time.
Steve
'95 Clubwagon XLT
