what do i plug the fuel lines with?
Old Jun 16, 2006 | 03:09 PM
bluneon's Avatar
bluneon
removing dual function reservoir for testing. whenever i remove the fuel disconnects at the tank side of the reservoir gas comes flowing out with no end in sight. what do i use to temporarily plug up the lines while i'm testing?
i need to remove these lines so i can test this valve. with my fuel selector switch on the dash set on front tank only the rear tank fuel level goes down after the truck has been run for a while. the front tank needle just sits at where i left it filled up to.
going through the low pressure pump diag procedures i notice that the front tank pump doesn't pump as much in volume as the rear tank.
now i've just noticed that my rear tank is leaking.
AAAAAHAB
16
Feb 22, 2015 12:18 PM
bout-time
13
Mar 18, 2014 07:36 AM
SSellers
20
Dec 24, 2013 12:47 AM
jerwiltho
Feb 21, 2013 09:08 AM
predaina
29
Mar 29, 2011 07:07 PM
