Divorced transfer case Ladder Bar?
Old Jun 16, 2006 | 01:56 AM
Rancho*Ryda's Avatar
Rancho*Ryda
hey i have a 76 f250 highboy with a divorced transfer case np205, just have problem as my other buddys do with all the slop and back and forth play with the transfercase when you put the throttle into it just wondering im going to make a ladder bar asap for my transfer case and just wondering if any of you guys have made one before or have seen this done? also if you have does it work well?
Old Jun 16, 2006 | 09:33 AM
77f2504by4's Avatar
77f2504by4
i think from the factory ford put a bar on the t cases. i have one on my highboy, its just a pipe with flattened ends, bolted to the tcase and a frame x-member. my tcase doesnt move at all.
Old Jun 16, 2006 | 10:29 AM
fordraceboy's Avatar
fordraceboy
replace all your mounting bushings with poy ones instead of the factory rubber ones, helps a TON!!
Old Jun 16, 2006 | 05:53 PM
averagef250's Avatar
averagef250
Most 73-77 F-250 4x4's came with them. Very easy to find one and bolt it in. Poly mounts work well too.
