Sponsored by: Real Truck
Vibration
Old Jun 15, 2006 | 04:11 PM
Bri-man's Avatar
Bri-man
Vibration
Hi everyone, I am a first time poster, long time follower.
I have a question about a problem I seem to be having with my 2000 4x4 CC PSD. The truck is completely stock except for a power programmer.
The problem I am having is a serious vibration that feels like it is coming from the rear end. I pull a 7000lb boat occasionally with the truck. The only time the vibration shows up is when pulling the boat while making a sharp turn (pulling out of gas station, turning on to on-ramps etc.). The vibration is not evident at all while not pulling the boat so it only occurs under load. There are no problems evident while pulling straight at all while accelerating.
Any help or suggestions are greatly appreciated.
Thanks.
Old Jun 15, 2006 | 04:38 PM
"Huck"'s Avatar
"Huck"
Sounds to me like the limited slip rear end doing its' job.
You do have the "limited slip", don't you?
Old Jun 16, 2006 | 08:58 AM
Bri-man's Avatar
Bri-man
Thanks for the input Huck. I honestly don't know as much about this truck as I probably should so I don't know for sure. I will have to look into that.
Old Jun 16, 2006 | 01:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Get the axle code from the door sticker and post back. Or see the FAQ at the top of the Superduty forum, it has the door codes on it.
Did you ever get the rear end fluid changed? It's possible whoever did it didn't put limited-slip additive in it and it's chattering.
Why wouldn't it do it without a load? Because you're really spinning the inside tire on the turn, ever so slightly. Maybe.
battmanf16
22
Mar 11, 2020 11:36 PM
ARK Ranger
2009 - 2014 F150
Jan 29, 2015 07:09 AM
377191
May 1, 2011 06:16 AM
rlreed
1997 - 2003 F150
Mar 10, 2011 02:56 PM
mowreyp
2004 - 2008 F150
Apr 17, 2005 04:02 AM
