when will it stop?
Old Jun 23, 2006 | 08:53 AM
fl1a's Avatar
fl1a
Also, the alternators' case is ground. Sorry about that.
Old Jun 25, 2006 | 11:06 AM
DRanchero's Avatar
DRanchero
Thanks for your help. After rewiring everything, I got it to charge. Hopefully the voltage regulator will last though. Thanks for everyone's help!
Old Jul 18, 2006 | 10:37 AM
DRanchero's Avatar
DRanchero
Alright, now everything has been working fine, but I have noticed that my voltmeter gauge still stays right below or at 12 volts when the motor is running. However, I keep checking the battery, and it shows 14.1 volts! It didn't bother me until last night, when I turned my headlights on; they worked for a minute, and then they went out. Could this be a faulty voltage regulator? Because if Im still only getting 12 volts to the dash, then maybe it only sends 12 volts to the headlights? Let me know what any of you think.
Thanks
Old Jul 18, 2006 | 01:00 PM
fl1a's Avatar
fl1a
That sounds like a bad regulator. You should get one rated for the alternators' amp
rating. Be sure to keep the battery disconnected until you get it all installed. Your
battery should be at 13.8v nominally.
Old Jul 18, 2006 | 06:04 PM
DRanchero's Avatar
DRanchero
Well, I replaced the regulator and it says it was a 100 amp. The headlights seem to stay on, but ill wait until tonight to drive around and see what happens. However, the voltmeter still doesn't show right, and now it looks like it possibly went lower. As of now, I had the gauge hooked to the same hot wire from the old instrument cluster plug-in (however, all of the 6 gauges are using power from it). Should I try to find another source? or should I plug it directly to the alternator somewhere or battery?
Old Jul 18, 2006 | 06:27 PM
fl1a's Avatar
fl1a
You might want to try another source, the battery would be more reliable, if you can
get to it easily. What does the meter indicate, as opposed to a multimeter reading?
Old Jul 18, 2006 | 08:08 PM
DRanchero's Avatar
DRanchero
Well, with a multimeter, the battery reads 12.8 sitting, and 14.1 charging. Inside, the voltmeter shows 11.9 sitting, and pretty much the same while the car is running...maybe even a little lower. I will have to take the multimeter to the hot wire at the gauges to see what it is exactly. I guess the gauge could be bad from the factory. If I wire it to the battery, would it possibly drain it over a long time? I may try to wire it in with the MSD ignition.
Old Jul 18, 2006 | 08:39 PM
DRanchero's Avatar
DRanchero
Also, if I wire it to the battery, do I need to ground it with the battery?
Old Jul 18, 2006 | 09:56 PM
Franklin2's Avatar
Franklin2
Do not wire it directly to the battery, it will drain it. Your idea of verifying the reading at the dash with the other meter is a good one.
