Sponsored by: Auxito
Trailor Lights
Old Jun 14, 2006 | 06:32 PM
HD328's Avatar
HD328
Trailor Lights
I have a 1998 150 4x4 with the towing package. I can not got 12vto the brake light pin or the blinker pin to the 4 pin connector or to the big round connector. Already checked ALL the fuses in both fuse boxs. I traced the brake wire out of the connector and it seems to go to the front of the truck?? Why would Ford do this , The brake light is in the rear. Oh well....Back to the problem. Am I missing something here ?? Ive had the truck since 2000 but really had no need to tow anything until now. Any help would be thankful.
Old Jun 14, 2006 | 10:54 PM
rtpalin's Avatar
rtpalin
You could unplug the trailer wiring harness along the frame and check the voltage there. It is possible there is a lot of corrosion inside the wiring at the plug. I just replaced my trailer harness because I was having intermittent problems with my trailer lights. That fixed my problem. It was $60.00 CDN from the dealer. I have a 1998 F150 with the Trailer tow package
Rick
Old Jun 15, 2006 | 06:10 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome HD328, to Ford Truck Enthusiasts!
See you on the boards. ….
