2002 trailer brake module install
Old Jun 14, 2006 | 05:02 PM
bkrfrmhell's Avatar
bkrfrmhell
Have a 2002 explorer that came factory with the big 7 pole trailer package and came with the brake module harness loose. Where does this harness plug in? I cannot find it anywhere? Would this vehicle already have the blue trailer brake wire to the rear plug also???
Thanks
Old Jun 14, 2006 | 05:04 PM
sglaine's Avatar
sglaine
Posting Legend
I can ask the dealer when I'm there in the morning if you would like and I will get back to you.
Old Jun 14, 2006 | 05:24 PM
bkrfrmhell's Avatar
bkrfrmhell
sounds good
Old Jun 14, 2006 | 06:12 PM
sglaine's Avatar
sglaine
Posting Legend
I'll be glad to ask for you
Old Jun 14, 2006 | 06:36 PM
Steina's Avatar
Steina
CO River Rat
It's behind the glove box; after you drop it down look up and to the left and you should see it, taped to a wire bundle or brace.
Steve
Old Jun 14, 2006 | 07:09 PM
bkrfrmhell's Avatar
bkrfrmhell
Thanks I'll check it out tonight.
Old Jun 14, 2006 | 07:20 PM
Steina's Avatar
Steina
CO River Rat
If you buy a brake controller with the correct harness (I recommend Prodigy), you can plug it in and not have to mess with splices on the factory harness. I used a long tie-wrap to pull the wires thru to the driver's side (clever Ford, putting the plug on the passenger's side).
Steve
Old Jun 15, 2006 | 12:38 PM
sglaine's Avatar
sglaine
Posting Legend
Steina, You nailed that one good.
Old Jun 15, 2006 | 04:53 PM
bkrfrmhell's Avatar
bkrfrmhell
Awesome...found it no problem. Ford dealer wanted 1.5 hours at $130 per hour Can. to locate it for me. Thanks a Million!
Old Jun 15, 2006 | 06:25 PM
Steina's Avatar
Steina
CO River Rat
If it takes a Ford tech 1 1/2 hours to find it, he and the service advisor should both be canned for not doing a little research first. Glad I was able to help.
Steve
