Tires
Old Jun 14, 2006 | 01:55 PM
X-RATED's Avatar
X-RATED
Thumbs up Tires
Im going to be needing some new tires. I'm going with BFG All terrain. But does anyone know the biggest i can go (285,305,315) on a stock aluminum wheel? My X is a 00 with diesel. Thanks for any help. And Im a newbie. I needed a vehicle to pull my mustang around with.
Old Jun 14, 2006 | 02:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
Have seen certain brands of 305's fit.
I would stick with no larger than 295, IMO. Just remember that your performance will decrease as your tire size increases unless you regear to compensate. Especially when towing.
Welcome to FTE!
Old Jun 14, 2006 | 06:11 PM
MadMedic20's Avatar
MadMedic20
I fit 305s on my stock height F250 (2000) but it doesnt look like they would fit or even come close to fitting my Excursion (also 2000). Stock my Excursion sits way lower in the front than my truck. My F250 rubbed the inner plastic fender well at full lock.
If im not mistaken arent 285, 295, and 305 all right around 33", like 32.6" or something. Isnt the only difference the width?
Old Jun 14, 2006 | 06:47 PM
gibaholic's Avatar
gibaholic
285, 295, 305 is the width of the tire... the second number is the aspect ratio of the sidewall to the width.....
so a 265/75/16 the height of the tire would be 75% of 265mm x 2 ( top and bottom side walls) + the height of the rim.
It is alot easier to use something like http://www.miata.net/garage/tirecalc.html
Old Jun 15, 2006 | 12:43 PM
XNrepair's Avatar
XNrepair
I bumped my tires 2 sizes from 265 to 285 and it SUCKED my power and MPG(20 to 16) !
Old Jun 15, 2006 | 01:33 PM
jhutche's Avatar
jhutche
I am in the process of buying new tires also. I currently have 285/70-17 BFG A/T's on a Motegi 17 x 9 rim. At 23k miles they are pretty ratty. They were rotated and balanced every 5-6k miles. The 285/70-17's fit fine. Might get 25k out of them, but they will be bald. No rubbing. My speedometer is now dead nuts accurate. Was about 5MPH off with the stock 265's. I was going to try a 295 or 305 this time, but BFG only makes a 285 & 315 in the 17". I am pretty sure a 295 would fit, a 305 might fit with some trimming of plastic but there is no way the 315's will fit without a lift. I am going to test a 33x12.50 (approx 305/70-17) to see what mods would be necessary. Pro Comp and Micky Thompson make and A/T in that size. Has anyone used those brands/models of tires?
Old Jun 15, 2006 | 10:43 PM
bmenzel's Avatar
bmenzel
Do you think 305 will fit on a 2005 4x4 Ex. There is some lift from the factory on the 4x4.
Old Jun 17, 2006 | 09:58 AM
toolboxjunky's Avatar
toolboxjunky
Question fuel mpg sucked=big tires
hey xn your 20-16 was that intown highway pulling or what
