1st Post, Need Help with high temp.
Old Jun 14, 2006 | 11:29 AM
texas-ranger-1's Avatar
texas-ranger-1
Unhappy 1st Post, Need Help with high temp.
Hello every one, I am new to the forum but have realy enjoyed reviewing the posts. I have a 1986 2.9 6 cyl. ranger I picked up a year ago for 800.00 bucks. the truck has 120k and runs great. Lately it has been overheating. I have since changed the fan clutch, radiator, water pump, temp. sensor switch, and themostat. The temp. gauge jumps back and forth between normal to high with or without the a/c on. I originaly put a 192 deg t-stat in and the temp. stayed at the high side of the gauge. I change to a 160 deg. t-stat. and it runs in the normal position until I get into stop and go traffic and it goes back up to the high side again. Since reading some of the other post, some recommend that you not use a 160 deg. t-stat ?. Please advise thanks.
Old Jun 14, 2006 | 12:51 PM
dono's Avatar
dono
Gone but not forgotten.
Welcome to the forum. Sounds like you might want to back flush the system to remove any crud that might be restricting flow. Good luck.
Old Jun 14, 2006 | 02:46 PM
AlfredB1979's Avatar
AlfredB1979
A t-stat won't help overheating, really. If the t-stat opens up at a certain temp, it sure won't help keep an engine from running at 240 degrees...
You've done all the relatively cheap fixes, but I bet those heads are cracked somewhere, somehow.
