balljoints
Old Oct 12, 2001 | 04:05 PM
helpmeplease's Avatar
helpmeplease
balljoints
im buying a 1971 f100 the balljoints need to be replace and they have bolts in them could somebody have switch knuckles i have been told that the balljoints should be of the press in type but from what i have seen these balljoints are bolted in?????
Old Oct 13, 2001 | 06:57 AM
StockMan's Avatar
StockMan
balljoints
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
I assume you are talking about a 4wd front-end?? There were several variations on the theme from the 60's and 70's. It would be hard to know what year your front-end came from without getting the ID tag info from the axle. Since you know you have the bolt-in type, why not explain that to your part person and have them order by part instead of application. Just a thought.
[/FONT]
https://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Signature"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="3" FACE="arial"]
[LINK:www.ford-trucks.net/users/stockman|Stockman's Club FTE Site]
[LINK:www.67fordtruck.com|1967 F-Series Registry ( www.67fordtruck.com )]
Old Oct 15, 2001 | 09:57 PM
67FordF100's Avatar
67FordF100
balljoints
Old Oct 15, 2001 | 11:32 PM
Nod's Avatar
Nod
balljoints
Helpmeplease, are you buying a 4x4? My 1971 F-100 4x4 frontend does not have ball joint knuckles that support and allow the front end to rotate.Mine has trunnion bearings, there are 4 sets of them in the front end,one upper and one lower each side.These 4 bearings are a smaller version of what you would have in a 2 wheel drive front axle.Each bearing has a race that needs to be pressed out and the new race pressed back in.These older setups are tricky to setup but with a few tricks can be made to produce years of trouble free service.Some of these setups were closed knuckle and some were open knuckled,mine is open knuckled as I can see the axle u-joint.Let me know if you have any questions.
"bowties in the rearview mirror"
