Column shroud removal?
Old Jun 12, 2006 | 06:18 PM
lahiggs's Avatar
lahiggs
I think I have a faulty MFS. I have searched hundreds of posts, but could not find one with a breakdown of removing the shroud. I read that is easier to remove by removing the lock cylinder, what else is required to remove the plastic shroud? Thanks...
Old Jun 13, 2006 | 07:53 AM
c_hohensee's Avatar
c_hohensee
All that should be required is some screws that come up from the bottom and as you wrote the lock cyl. should be removed.
Old Jun 14, 2006 | 08:27 AM
chopper269's Avatar
chopper269
Yeah. About 4 screws from underneath. The black cover pops right off the key cylinder. Before you replace the MFS, check the wires that plug into the connector. I have a 2000 and found that the problems I was having with the turn signals was not the switch. A few of the clips holding the wires inside the connector had broken off and were causing a bad connection. Just bought a new plug and inserted the wires into it.
Old Jun 14, 2006 | 08:31 AM
chopper269's Avatar
chopper269
The plug that went bad on mine was the one on the top of the MFS....
Old Jun 14, 2006 | 09:45 AM
projectSHO89's Avatar
projectSHO89
The lock cylinder must be removed to remove the lower shroud.
Disconnect battery.
Turn ignition key to RUN position.
Insert a small round object such as a 1/8" alllen through the hole in the bottom of the shroud, locate the corresponding detent on the bottom of the cylinder housing, and depress it (takes some patience/practice).
Remove the entire cylinder and key assy as one.
Steve
Old Jul 7, 2006 | 09:47 PM
lahiggs's Avatar
lahiggs
Fixed brake light problem. Wire was loose I suppose from tilting wheel. I bent the ends of the connector in a little and plugged it back in. Works like new. Thanks..
Baatzy
Jan 9, 2017 09:45 AM
willowbilly3
Jul 1, 2016 03:53 PM
Necromancer
Aug 23, 2015 07:12 AM
KRDiesel
Oct 20, 2012 06:34 PM
badfl97
2004 - 2008 F150
Mar 21, 2010 12:03 AM
