Dual cats
Old Jun 12, 2006 | 04:46 PM
RKG's Avatar
RKG
Dual cats
I'm getting ready to finish my sd to maf conversion and need to add the O2 sensor bungs. I've got a CA emissions 88 F150 5.8 with dual cats. I can't tell if they are welded or not. There aren't any clamps from the Y-pipe to the end of the outlet on the second cat. This leads to two questions.
Can they be taken off without cutting the Y-pipe so I can have the O2 bungs welded on?
Secondly, if not, is there enough room to add the O2 bungs with everything in place?
Thanks for any help you could give me.
Ron G
Old Jun 12, 2006 | 05:01 PM
4.9inline6's Avatar
4.9inline6
they are most likely welded. my 93's o2 sensor is inbetween the two pipes right before they y together. you could probably squeeze the o2 in right where they y and then just stick the other one in after the cat. is there enough room? if you are asking if there is enough space to place the o2 sensor, i would say yes. if you are asking if someone can move around in there to put in the o2, i would still say yes. good luck.
chris
