Removing Head Lights
Old Jun 11, 2006 | 04:04 PM
Wittmer321's Avatar
Wittmer321
Question Removing Head Lights
I got a new set of chrome head light doors to replace the factory grey set. What is the trick to removing the head light assembly? I removed the passenger side battery and removed one nut behind the light but it was still being held in by something else and I couldn't figure out how to get to it. You have to remove the whole assembly to replace the headlight doors because there are screws underneath that you can't reach when the light is in place.
Any help would be appreciated.
Thanks
Old Jun 11, 2006 | 04:28 PM
Cuda_jim's Avatar
Cuda_jim
This is what the manual says,
Headlamp Assembly
Removal
Remove radiator air deflector from radiator support.
Remove two screws and two nuts retaining headlamp door (13064).
Pull headlamp door from vehicle. Remove three bulbs and sockets.
Disconnect engine control sensor wiring (12A581) from headlamp bulb (13007).
Remove two retainers attaching upper two attachments of headlamp (13008).
Turn horizontal headlamp adjusting screw (13032) completely out of the adjusting nut.
Pull headlamp from vehicle.
Installation
Follow removal procedures in reverse order.
Tighten screws to 1.4-2.3 Nm (13-20 lb-in). Tighten nuts to 4-7 Nm (36-61 lb-in).
Check headlamp aim.
CJ
