switch
Old Jun 11, 2006 | 01:31 AM
1972ford_f-100's Avatar
1972ford_f-100
Smile switch
ok my 84 150 ,wut needs to be done so that i have no computer controlled over itcan i just switch to duraspark and pull off the stuff off the carb or do i have to get a dif. carb, wut do i got to do thx all
Old Jun 11, 2006 | 01:40 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
You will have to swap the Feedback Carb (computer Controlled Carb) with one from a earlier model without feedback.
Old Jun 11, 2006 | 02:45 PM
1972ford_f-100
wut about the tfi distributer,im gonna get rid of it,but for the time being if i take off the comp stuff will it run?
Old Jun 11, 2006 | 02:57 PM
81-F-150-Explorer
With just changing the distributor over to Duraspark II, It may run, without the computer, but not very well. Not very well at all. I seriously doubt you would be happy with the way it would run.
You really need to replace both the Carb and Distributor at the same time when doing this swap.
If you plan on keeping the EGR valve, it will need swapping too. If you plan on eliminating it, then you have to worry about possible pre ignition, depending on which carb you are able to get.
FWIW: A properly working EGR valve can save you Gas mileage.
Hope this helps...
Old Jun 12, 2006 | 11:44 AM
1972ford_f-100
but is it possible to just pull of the elecxtronic stuff off the carb and wut else has to be done if i want to keep the egr and get rid of everything else thx guys
