I have a 69 F100. I was trying to figure out if it was a 9 or 8 in rearend. If looking at it from the back there are no bolts to remove the rear cover. You have to remove the gears from the front of the housing. Is there a way to tell what this is without removing the rearend. Also is is a 2wd and factory 360 w/ 3 speed on colum.
