E-Brake cable swap
Old Jun 10, 2006 | 11:05 AM
michaelbrainardatwor's Avatar
E-Brake cable swap
I have a 77 F250 Camper Special Super Cab - originally had a Dana 60 Rear 4:10 with the heavy duty brakes ( 2.5" shoes I believe )...the axle was bad so I found a Dana 60 3.73 limited slip in a 73 ( with the standard duty brakes ) and did the swap.
The axle housings were different between the two so I couldn't swap the 77 brakes to the 73 axle housing so I was forced to rebuild the 73 brakes. No big deal, but the original 77 E-brake cables ( left and right ) wouldn't work at all. I have dealt with no E brake for about a year.
We use this truck to tow the boat and parking it on the ramp with no e-brake is scaring the ***** out of me.
I have been looking for a set of cables that will work but haven't had much luck. I purchased a set that I thougth would work but they are too long. They may actually WORK but I hate to tear the rear end apart to find out. www.partsamerica.com has MANY choices...I am not sure I will be able to find a combination that will work. At this very moment I am looking at cables which came up when I searched for parts specific to the 77....but I have also searched using the 73 model specs as well.
Anyone had this delima? HELP !!
Old Jun 10, 2006 | 11:28 AM
Mil1ion's Avatar
Mil1ion
Try here.
www.rockauto.com
Great site and they are a FTE sponsor
I looked it up for you.
http://www.rockauto.com/catalog/x,ca...,parttype,1696
Old Jun 10, 2006 | 03:08 PM
Good news...they did work. They were different than I had expected but work fine.
Although, the originals had a return spring on the "drum" end of the cable. The new ones did not....and they did not function. The return spring was on the WRONG END! WTF?!
That is fixed...and they do work!
