pulling valves
Old Jun 10, 2006 | 10:45 AM
77ford guy's Avatar
77ford guy
Question pulling valves
Hey! I have my heads pulled and am going to do some valve lapping. How do you get the valves out (and put them back in)? Do you need a spring compresser? Also, should i order new valve seals for re assembly or can i re use the old ones? Thanks for your help!
Old Jun 10, 2006 | 11:06 AM
rescuedranger's Avatar
rescuedranger
You will need a valve spring compressor, some auto supply stores will lend them if you put up a deposit.
Valve seals are cheap, replace them.
