I have a vibe @ 2200 to 2800 rpm. does not matter what speed nor gear. I put the trans and transfer in neutural. depress the clutch. ramp up the motor to that range in rpm . it vibrates.
I've replaced the clutch,flywheel ect..,fan fan clutch, pullies. the vibe is still there "unchanged"
I've always wanted a heavy duty deisel. Now I have it and it's driving me nuts.
Hope some one can help!!! ford trucks forever
JEFF
What kind of shape are your tires in? I had the same problem and it turns out all four tires were bad. I went and bought new Goodyear AT's and the problem got worse. Took the tires back and got some BF Goodrich AT's. Now it rides perfect. An unbelievable difference. I couldn't believe tires made that kind of difference.
