1990 EFI460? mods=poor idle
Old Jun 7, 2006 | 03:58 PM
stngh8r's Avatar
stngh8r
<note: also posted in the computer section>
I have a 90 EFI460 E4OD. It has a K&N CAI and free flowing catback. Shortly after installing the K&N, I had the battery cable off and since then it has not wanted to idle properly. The two events were so close together, I am not sure which one to blame. Driving the truck is perfect and it runs like a dream, its just the idle quality that is shaky, especially before getting warmed up?
Are the speed density 460's very sensitive to mods? Do I need a chip or something just because of the CAI and Catback? If I later go with a cam/headers is the problem going to get worse?
Any help would be greatly appreciated.
thanks
eric <><
Old Jun 9, 2006 | 08:28 AM
smooth's Avatar
smooth
Well, the standard is yes, Speed Density does not like mods, however, in my opinion (with some experience attached) what you have done should not have caused your problem. Frederic is a good one for info on what you can get away with, and what you can't before you burn a chip, or change your computer system. If you search, there are many posts that contain his wisdom on this.
As an example, my SD 302 in my bronco was replaced with a remaned short block bored .40 over. I put on GT40P heads with 60cc combustion chambers.
1.84 in./1.46 in. valve diameters. A comp cam with 206/212 Duration at .050.
462/474 lift. 114 Degrees Lobe seperation. Ford Racing shorty headers, and a K & N FIPK filter and it still runs strong. Now, I'm sure Frederic can give some insight into why it still works, I can not as most of these numbers mean little me other then "better then stock." I do believe my cam selection was mild for the purpose of working within the parameters of the SD system.
Anyways, I hope you find the problem!
MoMo
Old Jun 10, 2006 | 09:47 PM
7DF250's Avatar
7DF250
I am in the middle of reading Frederic's posts, he could awnser your ?'s for sure! or try www.fordfuelinjection.com lots of tech reading there. After reading up it sounds to me like a sensor or something is happening other than the mods.
Old Jun 12, 2006 | 08:37 AM
stngh8r's Avatar
stngh8r
Thanks for the valuable information. I was myself thinking that the mods themselves were not too blame, but just wanted to throw the question out there to be sure. I read a post that is a few pages back about a guy with a motorhome that did not want to idle and it ended up being a MAP sensor. I may try and rule that out first.
Any other tips/experience will be appreciated. It never hurts to get more info on the board.
Old Jun 13, 2006 | 04:25 PM
stngh8r's Avatar
stngh8r
Post
7DF250-Thank you for the fordfuelinjection.com link, it was very informative. Now that I have learned about a little thing called a IAB(idle air bypass) and its function to control engine idle, I think I will rule that out first. It seems that this little critter can obviously fail causing poor idle, but there is a possibility that a good cleaning of the part will take care of the problem.
link to the IAB description--> http://fordfuelinjection.com/index.php?p=39
Thanks
eric<><
Old Jun 19, 2006 | 05:35 PM
stngh8r's Avatar
stngh8r
I tried the IAB cleaning and it did seem to help intially, but when i started it the next morning, it was the same ol same ol, rough idle and then dies. The hunt for the problem goes on.
Old Oct 1, 2006 | 01:24 AM
stngh8r's Avatar
stngh8r
update 9-30-06: I tried pulling the K&N FIPK off and putting the stock air box back on and presto, it idles just like before. I cannot believe that a K&N FIPK would add so much air that it would cause the engine to idle poorly, but that certainly seems to be the case. FYI-I have also cut out the silencers in the tubes, which has further enhanced the ability for more air to flow freely into the TB.
Eric
FuzzFace2
15
May 21, 2016 09:53 PM
tony1947
Apr 4, 2010 11:41 PM
LukeN
Computer Chips & Tuners
Oct 10, 2006 11:10 AM
mike L
Jun 14, 2006 09:46 AM
