Air pump Q's
Old Jun 6, 2006 | 06:18 PM
Snatch Block's Avatar
Snatch Block
Question Air pump Q's
I just put in true duel's in my 90 F350. I had to cut off 2 steel tubes that connected to the large Cat, that I replaced with 2 hi-flow units. What does the air pump do? I know it pumps air...... Can I just bend the tubes closed and weld them shut? What effects will this have on the pump, or the system?
Old Jun 6, 2006 | 08:26 PM
benwantland's Avatar
benwantland
I'd just let them blow off into the atmosphere if you're not taking off the pump. That wouldn't hurt anything.
