Starter Question
Old Jun 6, 2006 | 02:12 PM
david00f150's Avatar
david00f150
Starter Question
I'm sure this sounds like a dumb question but I just put my new motor in my 87 F-150. For the wiring for the starter, there should be one wire directly from the battery to the starter, and one wire from the solenoid to the starter correct? If that is correct which post does the wire from the battery go to?
Old Jun 6, 2006 | 08:42 PM
S.N.A.F.U's Avatar
S.N.A.F.U
Theres a wire from the battery to the solenoid, then a wire from the solenoid to the starter, and a third wire from the ignition switch to the S terminal.
