need some computer codes asap
Old Jun 5, 2006 | 08:32 PM
truckin306's Avatar
truckin306
hey can someone with a 95 or 96 5.0 automatic with the e40d trans lemme have the number off of their computer, im trying to order one to try to get my mass air conversion completed, but napa has a ton of numbers, and thats where i can get my discount, help please
F4TF AAA
F4TF ABA
F4TF APA
F4TF APB
F4TF ARA
F4TF ARB
F4TF AVA
F4TF AXA
F4TF BBA
F4TF BBB
F4TF BCA
F4TF BCB
F4TF GB
F4TF HB
F4TF JB
F4TF KB
F4TF APC
F4TF BBC
F4TF BCC
those are my options, i have a 92 e4od 5.0 with a 3.L55 rear ratio, tach, ac, cc, pw, pl pretty much every option not sure what i need to know, or what is actually controlled by the ecu on this
Old Jun 5, 2006 | 09:12 PM
truckin306's Avatar
truckin306
bump bump bump bump
Old Jun 6, 2006 | 07:41 AM
water 5's Avatar
water 5
check www.fordfuelinjuction.com under EEC program codes they give a list of computer codes you should be able to use w/mass air and E4OD trans.
Old Jun 6, 2006 | 09:39 PM
truckin306's Avatar
truckin306
i matched up what i needed, which is a e4od 5.0 maf, but theres 3 different ones, and not a one of em matches up with ne of the numbers
HUG2
5.0 Bronco, F-x50 E-x50 MAF / E4OD (see note 1)
VEX1
5.0 Bronco, F-x50 E-x50 MAF / E4OD / F5TF-12A650-HB (see note 1)
WAY1
5.0 Bronco, F-x50 E-x50 MAF / E4OD / F5TF-12A650-JB (see note 1)
thats what i got out of it, now what?
Old Jun 8, 2006 | 09:26 PM
truckin306's Avatar
truckin306
nobody with any hookups?
Old Jun 8, 2006 | 09:39 PM
water 5's Avatar
water 5
I would go with the VEX1 or the way1 becouse they seem to be more tunner friendly for aftermarket chips.
Old Jun 8, 2006 | 10:11 PM
truckin306's Avatar
truckin306
what made you come to that conclusion? any of the 3 will work for me?
Old Jun 8, 2006 | 10:19 PM
Blurry94's Avatar
Blurry94
Yes, anyone of those will work for an E4OD/mass air conversion.
What water 5 means is that the VEX1 and WAY1 would be more 'tuner friendly' should you decide to go with some type of aftermarket tuning.
AKC0 and BIO1 are also programmed for mass air/E4OD applications.
Old Jun 9, 2006 | 07:49 PM
truckin306's Avatar
truckin306
well, whats the difference in the 2 of em, and how do i match em up with one of em on the first list, those are the ones that i can order
Old Jun 9, 2006 | 08:23 PM
subford's Avatar
subford
Originally Posted by truckin306
HUG2
I do not know about the rest but this is wrong. The HUG2 is off a 94/95 5.0 MAS with an AODE (4R70W) and not the E4OD.
Also what you listed in your first post are part numbers with the base number missing and the second from fordfuelinjuction.com are Program Codes. You are trying to mix apples with oranges
Old Jun 9, 2006 | 08:56 PM
truckin306's Avatar
truckin306
well, a hook up of mine at napa gave me the one set of numbers to order from,
Old Jun 10, 2006 | 12:41 AM
truckin306's Avatar
truckin306
bump bump bump bump
Old Jun 10, 2006 | 06:27 AM
subford's Avatar
subford
I may be wrong here but I am going to say it anyway, please somebody correct me.
Just in reading posts I came to the following conclusion and I am not saying that fordfuelinjuction.com all wrong here as the information is hard to come by.
What I think I have read is that the 1994 and 1995 5.0 F150 with the 4R70W had MAS and no F150 had the E4OD.
The F250 in 94 and 95 had the 351 and E4OD with MAP system.
So there is not any PCMs in the 1995 Fords for an E4OD with MAS.
I hope I am wrong but from reading this is what I come up with.
Old Jun 10, 2006 | 11:02 AM
Blurry94's Avatar
Blurry94
my 1994 is an E4OD and also mass air but the truck is 4-weel drive if there is a difference on 2-weel drive trans. setups?
Old Jun 10, 2006 | 11:33 AM
subford's Avatar
subford
If what you say is true and maybe for the Lightning it is, I think he would like to have the Program Code and the Part Number off your PCM.
