need some computer codes asap
Old Jun 10, 2006 | 12:40 PM
water 5's Avatar
water 5
I accidentally responded while my brother was still logged-in (Blurry94)
My 94 F-150 5.0 4x4 (mass air) does have an E4OD in it. The stock computer calibration code was HOG0, and now I'm using an AKC0 (ECU for a GEN 1 Lightning mass air conversion) because it is/was easier to get tuning support fot it.
The part number for the AKC0 ECU is; F8TF-12A650-NA
Old Jun 10, 2006 | 11:22 PM
truckin306's Avatar
truckin306
you're happier with the lightning computer than the other one? did you chip it?
Old Jun 11, 2006 | 08:33 AM
Blurry94's Avatar
Blurry94
The database for the AKC0 is much better than the HOG0 that originally came with the truck. The ECU, 30lb injectors and air meter are from a mass air conversion kit I had for my Lightning.
Tuning with the HOG0 was limited and there weren't any parameters/tables to tune the transmission. One thing we both like about it (ECU, MAF and 30lb'ers) is that the truck can still be driven without the chip.
Old Jun 11, 2006 | 12:12 PM
truckin306's Avatar
truckin306
so what you're saying is that i can get my harness, my maf sensor, some 30# injectors and the AKC0 ECU (F8TF-12A650-NA) and i can have my kit completed? if thats true alls im going to need is the ecu and injectors.
by the way this is going on a 5.0 bored .030 over with gt40 heads, edelbrock performer efi upper and lower intake manifold and other stuff to back this up. and a fully built e4od, so the all the lightnings had the e4od trans?
Old Jun 11, 2006 | 12:18 PM
Popa Tim's Avatar
Popa Tim
Originally Posted by Blurry94
my 1994 is an E4OD and also mass air but the truck is 4-weel drive if there is a difference on 2-weel drive trans. setups?
Ditto - another 94 mass air e4od here in my 4x4 F150
Old Jun 11, 2006 | 08:46 PM
truckin306's Avatar
truckin306
hey bump, not just for me
Old Jun 12, 2006 | 11:05 AM
Blurry94's Avatar
Blurry94
If you want to use the 30lb injectors without a chip, then yes...just be sure the MAF and ECU are the ones from the Lightning MAF conversion. I've read where the MAF is the same on a Lincoln Mark, but I've never seen it myself.
The combo you're building would benefit from some type of aftermarket tuning. And yes, all GEN 1 Lightnings were equiped with E4ODs from the factory.
Old Jun 12, 2006 | 10:36 PM
truckin306's Avatar
truckin306
motorsport/ford racing doesnt list a lightning maf conversion kit, whered u go?
Old Jun 13, 2006 | 04:56 PM
Blurry94's Avatar
Blurry94
Unfortunately, Ford doesn't sell that kit anymore. There are some used ones floating around (from other GEN 1 owners), but if you can get a complete engine harness from and mass air'd f-150/E4OD, then that'll work too.
PMAS is looking to recruit a GEN 1 owner to test their MAF conversion kit at this time. It utilizes an EEC-4 Mustang ECU and a stand-alone trans controller for the E4OD. That kit will be sweet once they finish it with it.
Old Jun 14, 2006 | 06:10 PM
truckin306's Avatar
truckin306
i have the harness, just need the ecu andits getting to be an endless search
Old Jun 14, 2006 | 09:54 PM
Blurry94's Avatar
Blurry94
Other calibration codes to look for are BIO1, VEX1 and WAY1. Those are cal'd for 351's and E4ODs. You could use an ECU from a 302, but the engine displacement, timing and fuel tables will be a little off for a 351...nothing that a little aftermarket tuning can't take care of though.
Old Jun 15, 2006 | 07:57 PM
truckin306's Avatar
truckin306
okay wel i guess the question now is where to buy-everyone's askin for calibration and i cant give it to them
Old Jun 15, 2006 | 09:01 PM
  #28
Blurry94's Avatar
Blurry94
The calibration codes, are they not enough....do you need actual part numbers???
Old Jun 16, 2006 | 11:07 AM
  #29
truckin306's Avatar
truckin306
yea, so if AKC0 is the calibration code, whats the part number for that one F8TF-12A650-NA is no good, not found
Old Jun 16, 2006 | 12:42 PM
  #30
Blurry94's Avatar
Blurry94
That is the number directly off of the ECU. That particular one is rare being that it comes in the conversion kit. You might be better off finding a complete kit, that way the air meter and possibly the injectors will be included.
