I've gone that route, years ago, and would advise against it.
Your radio may blow out, your gauges won't work right, all your light bulbs will burn out faster...
Assuming your intention is to get better cranking, you'd be way ahead to get your starter rebuilt and new battery cables.
Don't know what you're driving; if it's a high compression engine you might want to investigate the 6/12 systems with a relay that runs the starter at 12v and everything else at 6v.
NAPA Has it (Or can get it) It's part number 8201.Dimentions are 9 1/16L X 6 7/8W X 9H Obviously the counterman you talked to doesn't know how to read a catalog
With the 8 Volt battery, you may be compensating for a problem that you could easily fix. Clean connections with short, fat (0 gage) cables will make a big difference.
Hey guys
My truck is a flat head v-8,I put all new battery cables on,and cleaned every connection to the starter,and battery,it just turns over slow,and I thought a 8 volt battery would be the way to go!
I had a 52 Pontiac straight eight years ago with the same problem...especially when it was hot. The 8V battery solved the problem and I never had any electrical gremlins either.
Vern
...I got mine at the local "Interstate Battery" distributor. They stock 'em for forklifts. Fits the F-1 batterry box perfectly.
I ran an Interstate 8V for several years in my 55 and did not "blow out" anything (have no radio). Switched to an Interstate heavy duty 6V 2 yrs ago and it is great. Don't have to mess with the Voltage Regulator setting it to charge 8V.
I ran an 8volt in an old 49 Cadillac that had starting problems when cold, but ok when warm or hot (anyone have a quess, it took me forever to find the problem) never had any problem with any of the electrical, most 6volt systems are designed to take 8volts, and 12volts are designed to take 14
A fully charge ready to go 8 volt battery, if tested with a multi meter will / should read 9.8 to 10.2 volts ? If I remember correctly...... 8 volts about 90%
of the capacity.
