Scorched oil
Old Jun 5, 2006 | 01:30 PM
seneca's Avatar
seneca
Question Scorched oil
I installed a Weiand 8010 intake manifold on my Ford 351m400 cid engine without the valley pan. I ask Weiand if the oil hitting the bottom of the hot manifold would scorch the oil, as I have read. Their answer was -"This should not be a problem". Not much of an answer,was it?
The bottom line is that the oil is scorching in less than 100 miles. The engine has less than 500 miles on it and has not been over 50 mph yet.
Can anyone tell me if this can be corrected.
Thanks in advance.
My trucks name is Gnarly.
Old Jun 5, 2006 | 05:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Put the turkey pan back in.
Old Jun 5, 2006 | 07:54 PM
danlee's Avatar
danlee
If the intake has an exhaust crossover, then you need the turkey pan. The Weiand 8010 has the crossover. You could try to block it off, but short of welding it closed there is no guarantee that it will not burn through.
Old Jun 5, 2006 | 08:15 PM
Socketman's Avatar
Socketman
HI, I use the MR gasket 720-222 listed at jegs, i think the 720 prefix is their in house number so i believe i just ordered 222. It comes with 2 small plates made of stainless and i have never had a problem and i burn barbeque fuel lol
Old Jun 5, 2006 | 08:34 PM
danlee's Avatar
danlee
Good information Socketman!
Old Jun 6, 2006 | 10:22 AM
seneca's Avatar
seneca
Thanks for the info. I'll call Jegs today.
Old Jun 6, 2006 | 05:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
In Florida you should not have to many driveability problems from not having a heated intake but other locations could have problems.
Old Jun 7, 2006 | 07:09 AM
seneca's Avatar
seneca
Scorched oil
Too many drivability problems?--- I want 0 drivability problems. What good is a heated manifold when it ruins the oil after driving 3 or 4 miles?--and, who knows what the scorched oil is doing to the new engine. Somebody please tell me why the maker of the Weiand manifold doesn't know what several members of this Forum knows.
Thanks,Seneca
Old Jun 7, 2006 | 10:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
The heated intake helps to vaporize the fuel and improve cold starts and cool engine driving. If you want zero driveability problems keep everything stock. Use the turkey pan, heated intake, and heated intake and outside air system. Ford had it designed right in the first place.
Old Jun 8, 2006 | 04:56 PM
seneca's Avatar
seneca
Thanks,Torgue1st
I live in Saint Petersburg Florida. It's hot here most of the time ,do you think I can install the turkey pan and forget about the heated intake and thus stop the scorching of the engine?
Old Jun 8, 2006 | 07:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
See the posts on carb icing in the 73-9 forum and check the charts with your local temperature and humidity. If you are in icing temperatures you can use the heated air intake and block off the exhaust crossover passage. The crossover will not prevent your carb from icing, it helps, but does not prevent.
Old Jun 12, 2006 | 01:40 PM
seneca's Avatar
seneca
Scorched oil problem repair
Thanks in advance.
OK Fellas: I removed the 8010 Weiand intake manifold to install a turkey pan because I suspected that the exaust crossover was scorching the oil. When inspecting the bottom of the manifold I found it to be as clean as new.---However, when comparing the turkey pan gasket to the old gaskets still on the heads, I found that the crossover ports were blocked ---(never punched out by the manufacturer.) The manifold crossover ports were as clean as a whistle.
Could this be what is causing the oil to be black after only 5 or 6 miles,in some way?
Yes,I did check compression. It's fine.
Thanks in advance
Senaca
Old Jun 12, 2006 | 02:29 PM
Socketman's Avatar
Socketman
when you say scorched oil. do you mean it smelled burnt or the fact that it was black. take some of the oil and rub it between your fingers it should feel really slippery( hard to explain) , what i am getting at is if its diluted with gasoline say from a bad fuel pump or leaky carb it may be whats deteriorating your oil. Smell the oil and see if it seems really gassy. I would pull the spark plugs and see if they look sooty or black indidcating a too rich mixture.
Old Jun 12, 2006 | 03:30 PM
seneca's Avatar
seneca
Socketman
Did you see the part where the old gasket is blocking the crossover?
Yes, the oil is very close to black and does smell of gas. First--- Could the blocked crossover cause this problem?
Second---The carb is a new Ederbrock 600, Holly electric fuel pump set at 4.5 psi.
Timing is 18 degrees btdc. It runs perfect--but does seem to be too rich. If carb is too rich--how does gas get into the oil?
Seneca
Old Jun 12, 2006 | 07:07 PM
danlee's Avatar
danlee
An overly rich mixture will wet the cylinder walls, and sooty fuel will make it's way past the rings and into the oil.
Check your plugs, are they wet and sooty?
Check the float level in the carb, just because it's new doesn't mean that it is right.
4.5 lbs fuel pressure shouldn't cause any problem with the needle valve, but one could be stuck open from shipping a new carb.
Look for fuel dripping into the carb as it idles.
