Helper leafs
Old Jun 5, 2006 | 12:06 PM
oem78's Avatar
oem78
Helper leafs
I found a pair of bolt on helper leafs for $20 from a yard, they are only 2 1/2
inches wide, they bolt to the exsisting leaf set. The leafs on my truck are 3 inches wide, the truck is a 1979 F150. Will these work? The yard says yes. I guess if the 4 ubolts are wide enough to go over the 3 inch leafs they will work ? Any one have a set up like this? JC Whitney sells 2 1/2 inch also, I thought they should match the leaf size on the truck any comments? The reason I'm thinking of getting them is I pull a 1977 Reinell boat 20', the boat and trailer are just under 5000 Ibs. and the suspension is taking a load.
Old Jun 5, 2006 | 02:40 PM
fordraceboy's Avatar
fordraceboy
don't go cheap, you'll probably regret it. get either some add a leafs that are the proper width or a set of helper air bags. i like the airbags because they are a bit smoother as you can air down with no load. add a leafs are rough as a buckboard unless you're loaded. JMO
Old Jun 5, 2006 | 02:58 PM
1975Ford's Avatar
1975Ford
Match the width of the helper leaf and the OEM leaf springs. It will be a safer truck. http://www.suspensionconnection.com/...on/61602F.html
Old Jun 5, 2006 | 06:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Helper leafs are generally worthless. Get your springs reconditioned at a spring shop. They can add a leaf if necessary.
Old Jun 5, 2006 | 07:39 PM
dakonthemountain's Avatar
dakonthemountain
Hey Eric, I don't understand what you mean. I use Helwig overload springs (J.C. Whitney)on Burt because of the heavy camper I have on him. They do a great job helping to correct any unwanted sag (now if I can get some for my face!.) I have also had them on other trucks and always had success with them, as they do what they were intended to do.
In terms of safety, I do have the bigger Dana 70hd rear end and adjustable air shocks too.
If in fact his factory springs are coming unsprung, or are shot, then I agree that adding helper springs would be the wrong thing to do though.
Just my experiences.
Dak
Old Jun 5, 2006 | 08:17 PM
western star's Avatar
western star
another option would be a RoadMaster active suspension system. you can see pics in my gallery. i put it on my truck to make hauling my camper safer. only cost me $320 cnd. better than helper springs as it doesn't ruin your unloaded ride quality. check out www.activesuspension.com
Old Jun 5, 2006 | 10:38 PM
MBBFord's Avatar
MBBFord
I completly agree. My dad tried putting some on his truck a few years ago, and they did nothing, and one even fell off, and neither side was higher that the other. New spring pack, add a leaf, or reconditioned spring would all be a better choice.
Old Jun 5, 2006 | 11:14 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have had several on various vehicles by various brands over the years and they did nothing. Now I just have the springs serviced. In and out in a couple of hours and everything is like new or better.
Old Jun 6, 2006 | 08:47 AM
1975Ford's Avatar
1975Ford
I highly reccommend these type of setup http://www.stengelbros.com/HeavyDutyHelperKits.htm refer to type 1 or type 4. These overload keep the original truck height, and have a smoother ride when loaded or unloaded.
You can find these styles of overloads on OEM setup on factory F250's, F350's and on some F150's.
Buck
Old Jun 15, 2006 | 12:55 PM
1975Ford's Avatar
1975Ford
Here a set of helper leafs. https://www.ford-trucks.com/user_gal...=89153&width=0
Old Jun 15, 2006 | 02:27 PM
73Custom's Avatar
73Custom
Buck
I have the same style OEM ones on my '73. I got the hangers and springs from a '76 F150 and bolted it up to mine (holes were already in the frame). When empty the helpers don't touch, so don't affect the ride. But when loaded they keep the rear from sagging too much. I really like them. Parts were free, just needed $40 worth of U bolts.
Marty
Old Jun 18, 2006 | 12:03 PM
MBBFord's Avatar
MBBFord
Like 73custom said, go to a junkyard and find a F-150, and get the springs and hangers. Any F-150 from 75-96 will work. I have some 86 F-150 springs on my 77 F-100.
Old Jun 18, 2006 | 01:40 PM
Purely Ford's Avatar
Purely Ford
My 76 F100 has OEM overload springs and they do help. Like what was already stated, they don't affect the unloaded ride quality and are only engaged when the truck is loaded.
In my opinion, OEM overload springs should be rated as very functional and helpful.
