stalling problem
Old Jun 5, 2006 | 11:15 AM
strato1's Avatar
strato1
stalling problem
Hi guys. I've had my '49 on the road for a few months now and am having a blast I drive it almost every day. Drives like a champ. Just a refresher I'm running a 302, 4 bbl carb c-4 etc. Yesterday I went to crank it up and it took a few tries, but fired up (not commonfor this car). Went down the road a bit and it stumbled for a second then regained power. Went back home popped the hood and looked it over while running. Seemed fine. I have a clear fuel filter and it was full of gas. So I went back out on the road. Came to a stop sign and noticed it was running a little funny. Hit the gas and it sputtered and died. I coasted to a safe stop and then it took a couple of tries to fire, then it fired up and I drove it home.
I'm thinking it might have a piece of dirt or something in the carb? Your thoughts? I'm running an Edlebrock 4 bbl carb and it is nearly new. I cleaned and sealed the tank when I was building this vehicle so I doubt that is the culprit. I have driven this vehicle about 1,000 mi since getting her on the road in April and this is the first real problem. Need help!
Thanks in advance!
Old Jun 5, 2006 | 11:43 AM
Kemicalburns's Avatar
Kemicalburns
maybe the fuel pump is failing
Old Jun 9, 2006 | 11:10 AM
strato1's Avatar
strato1
I just noticed that one of the vacum port caps is craked and is likely letting air in. Could that be it?
