oil Press.
Old Jun 5, 2006 | 05:36 AM
redrock233's Avatar
redrock233
oil Press.
When I start up the truck it seems that the oil press sensor on the dash is taking a bit longer to move and also I can tell just by the noise the engine makes it seems to take a bit longer than normal to go up. Is there any ideas as to what this might be? Just changed the oil about 2000 miles ago but I did notice that it was starting to do it before that oil change. It's a 04 F-250 cc fX4 sb 47,000 mi with diablo predator in 65 hp mode 4" exhaust. The truck still runs great would not get rid of for nothing this is the first problem that I have noticed on the truck. I did put all them miles since July 04 when we bought the truck new.
Old Jun 5, 2006 | 09:08 AM
kw5413's Avatar
kw5413
What kind of oil are you using? Have you changed oils?
Old Jun 5, 2006 | 10:52 AM
redrock233's Avatar
redrock233
I shifted over from rotella to delavac cause could not find rotella that weekend I am going to change back over to rotella tonight just to see what happens.
