Started out simple...now it's a HUGE problem...HELP!!!
Old Jan 17, 2002 | 01:54 PM
badboyina67's Avatar
badboyina67
My 1967 240 6 cylinder started acting up yesterday. The truck was running very very rough, I thought it was the choke, but it's not. When I shut it off in the driveway, it wouldn't start. The solenoid just clicked. After about an hour or so...it started. This morning, I was on my way to school and it did it again, same exact thing. I came out from class and the truck wouldn't start. I had to get a jump to get it started. I began driving it home and it started running rough again. Then it began to backfire...the second time it backfired, it blew the welded seam apart on the muffler. Does anyone know why this happened and where to begin chasing this problem. I know I have some electrcial problems, but why the rough running and backfiring??
Ken:-staun
Old Jan 17, 2002 | 02:09 PM
Mil1ion's Avatar
Mil1ion
First off, Take the battery to an auto parts place and get it tested.
To make sure it is Good or Bad
Intermittant Ignition problem !
The back firing can come from:
1)an open-then closed circuit in the ignition switch.
2)by turning the key off / on while driving.
3)bad timing or worn out distributor.
4)Ign.Points
5)Ign.Coil
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 17, 2002 | 03:20 PM
unioncreek's Avatar
unioncreek
I had this happen on my 72 with a 360. It backfired so hard it split the seam on a new muffler. I hadn't had it long when this happend. It started right up and then run crappy all the way home. I changed the points and plugs and have never had it happen since.
Bob
Old Jan 17, 2002 | 03:56 PM
southernpride's Avatar
southernpride
HEY MAN ITS ROBLEY YOUR PIN ON YOUR CAM OR YOUR OIL PUMP. TAKE THE CAP OFF YOU DISTRIBUTOR WHICH OIS VERY SIMPLE 2 PINS JUST POPO THEN DOWN THE U WILL SEE YOUR ROTER BUTTIN SEE IF IT HAS ANY PLAY OR IF IT WILL SPIN ALL THE WAY THE IS IS THE PININ YOU CAM BROKE OFF IF NOT TRY OIL PUMP THAT IS MY BEST CHOICE ANYWAYS
Steve
Old Jan 17, 2002 | 04:15 PM
Mil1ion's Avatar
Mil1ion
Steve,
Welcome to FTE.
Could you please Post in *Lower Case*
Posting in Upper Case is Not only *Hard to read*
It's Considered as *Yelling*
Most people have a tendency to By-Pass All Caps Text!
Thank you !
Dennis
Old Jan 18, 2002 | 07:13 AM
rtbstrd's Avatar
rtbstrd
tkisling
18
Jan 12, 2017 07:43 PM
Tim Maloney
Jan 11, 2017 08:40 AM
areoseek
21
Dec 3, 2015 12:21 PM
JohnBOV43159
53
Feb 7, 2014 11:11 AM
Bruce C
Apr 2, 2005 10:54 AM
