edge help needed..
Old Jun 4, 2006 | 07:43 PM
mik369's Avatar
mik369
edge help needed..
hello to all.
Really need help.. Took out my edge friday after returning it to stock to have some warranty work done. Decided to put back today ang just use the shift mode. After doing so it won't start I tried everything, can anyone help!!
thanks, mike
Old Jun 4, 2006 | 08:32 PM
DASTUD's Avatar
DASTUD
Have You Done An Update Yet? If Not, Plug It Into Your Computer And Do The Update With The Lightning Software, Plug Back Into Your Truck And Program To Your Liking, It Should Fix The Problem.
Old Jun 4, 2006 | 08:55 PM
mik369's Avatar
mik369
datsud
thanks for the reply but while I had it out I tried it and still nothing.
mike
Old Jun 4, 2006 | 09:20 PM
DASTUD's Avatar
DASTUD
Man, I Wish I Could Help. You Will Have To Call Edge Products In The Morning. I Know That When I Program My Truck To The Performance Setting, I Start The Truck And Push The Gas And It Goes Into Safe Mode And Will Not Allow The Truck To Go Beyond Idle, But When I Turn The Truck Off And Re-start, It Is Fine. But Man, You Cannot Even Start The Truck. I Am Sure That Someone Has Had This Problem.......come On Fellas Let Us Hear Some Advise.
Old Jun 4, 2006 | 09:25 PM
mik369's Avatar
mik369
hey dastud
I have to apologize for all the wrong spelled words but thats how fustrated I'am. But the bright side is I get to take wifes 2006 mustang to work tomorrow..lol
thanks again . mike
Old Jun 5, 2006 | 08:44 AM
the4by4freek's Avatar
the4by4freek
Mik369, When you plugged your Edge back into your truck did you turn the key on first then plug it in? If not try that sequence. Also Did your hex file show up on your Edge? When you returned it to stock before removal, did you enter restore defaults or return to stock? If you hit restore defaults then you didn't return it to stock. Edge should be able to help you get it straight. Call them up. They are really nice to deal with.
Old Jun 6, 2006 | 07:59 PM
mik369's Avatar
mik369
thanks to all,
talked to ken at edge products he got me going again. what happened was I had my truck in for service and they reflashed the computer with out me knowing, but ken at edge figured it out the only thing I can say is wow, those guys are great, don't get that kind of help from dealer.... mike
Old Jun 6, 2006 | 08:40 PM
yellow98cobra's Avatar
yellow98cobra
Originally Posted by mik369
thanks to all,
So what did Edge have you do?
Old Jun 7, 2006 | 07:28 PM
mik369's Avatar
mik369
yellow98cobra,
they had me hook my edge up on pc send them a file and try it , but first time it didn't work so I sent the remaining 2 files and they sent a file back. Took it out and plugged it up and it fired right up. Then took programmer back to house he reprogrammed that took it out and just went through the sequence and its fine.
These guys know their stuff to say the least this is why I bought the programmer to begin with...
Mike
Old Jun 7, 2006 | 09:23 PM
yellow98cobra
Thanks I was just wondering...
I think there instruction manual leaves a step out. All it tells you, you have to do to reset back to stock is to set it to select restore defaults. I doesn’t mention returning to the power programming page and selecting return to factory settings
