What do you think
Old Jun 4, 2006 | 07:37 PM
redneckboy's Avatar
redneckboy
What do you think
Tere is vibration that comes from the passenger side of my truck. You can feel it very little on the drivers side. It is mainly when you first start the truck but it dont matter how long it has been shut off. I had a leak from the o-rings on the fuel bowl drain valve and I fixed that but the vibration is still there. The vibration pretty much goes away after about two miles of driving. It is not there when I am actually drivng just at idle. I reset the computer and it went away for just a little while. I tried playing with my exhaust system cause I thought maybe the five inch was rubbing. It changed the the way the vibration was but I dont see why. If it was the exhaust why would it only do it when i first started the truck. Here are the possiblites I have come up with.
High Pressure oil pump
CPS
Fuel Pump
IPR
What do you guess think yes or no on any of these and do oyu have any more suggestion and what do you tink I should try first. Thank you for any help.
