Sponsored by: Kumho
brakes
Old Jun 4, 2006 | 03:46 AM
demonfang's Avatar
demonfang
brakes
could anyone tell me how to change my brakes please? the back breaks i can do myself but i'm not sure if they are shoe or pad. i don't want to have to take off the tire to look until i'm actually fixing it. the front has disc and those i know i will not be able to do. i need brakes BAD so any and all help would be greatly appriciated. and please don't be rude.
Old Jun 4, 2006 | 07:45 AM
holland501's Avatar
holland501
A little more info please. The type of vehicle would be of help. I would suggest buying a manual for whatever it is you have. If not that, at least a trip to the book store and read one there. Most libraries have reference books you could check also. Good luck.
Old Jun 4, 2006 | 09:42 AM
SRD4X4's Avatar
SRD4X4
Like Holland said,your best bet is a manual.Fronts are almost always easier than the rear (if you have rear drums).I would suggest pulling atleast 1 front/1 rear wheel to see what the condition of the linings are.Let us know what your working on and what the symptoms are.
Old Jun 12, 2006 | 03:23 AM
Leader's Avatar
Leader
Disk brakes are much EASIER to change then drum brakes. You CAN do both. And do it MUCH cheaper then haveing someone else do it.
Old Jun 12, 2006 | 10:40 AM
rebocardo's Avatar
rebocardo
> i need brakes BAD
If you have a grinding metal on metal sound instead of just squealing, you most likely need rotors and maybe drums. You can either buy a Haynes repair manual and learn how to do it yourself or take it to a dealer or repair shop. Rotors are not a big deal on most Ford trucks.
