302 to 351w
Old Jun 4, 2006 | 02:55 AM
1958 DOHC's Avatar
1958 DOHC
302 to 351w
alright i got an easy one for you guys. ok i have a 1969 f100, it has a 1969 or around there 302 2 barrel in it and a c6. the motor is running like hell and we have a rebuilt 1986 4 barrel 351w sitting here. the motor is semi complete with intake, carb, and manifolds, the question is what from the 302 will work on the 351. distributor, linkage, and will the c6 just bolt right to it, which flywheel to use and stuff like that. any help would be greatly appreciated. thanx
Old Jun 4, 2006 | 03:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Old Jun 4, 2006 | 04:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
since the 302 and 351w are basically the same engine, you should be ably to direct swap them. the only thing you need to check on is the weight of the flywheel, (28 oz compared to the newer 50 oz) and exhaust manifold size. the dist, water pump, and trans are the same mounts. the biggest thing i can see in the swap is maybe fabricating a new throttle linkage to compensate for the difference in length between the 2 bbl and 4 bbl
Old Jun 6, 2006 | 11:17 AM
Kemicalburns's Avatar
Kemicalburns
the distributor will not work. you must use a 351w specific one
Old Jun 6, 2006 | 02:34 PM
ken75ranger's Avatar
ken75ranger
You might need some brackets to lower your accessory drive. The 351 is about an inch taller. Watch your 351 oil pan too. Some fit some don't.
Old Jun 8, 2006 | 12:09 AM
1958 DOHC's Avatar
1958 DOHC
alright cool thanx for all that and i think we have the right oil pan from Ford Racing so we should be good. thanx fellas
