Engine noise maby y pipe????
High pitched goes away with a little throtle.Thinking its in the Y pipe maby or a heat sheild....
I asume becuse the engine flexes up a little under load sound goes away..
Had a look under but could not find much...
Any ideas???
Thanx
F4B
Remove, bend in the middle, reinstall, extra tension from the bend usually fixes the vibration. Some folks make a new one heavier, others stick on sound deadener materials
Could also be broken welds on some of the exhaust heat shiels.... band clamps work
And not to forget the factory "T" two to one "collector" is a piece of crap and can cause "flutter" under load at certain RPMs... fix the mechanical vibrators first..if annoying sound still present have a real "Y" pipe fabricated at a good muffler shop.
