Twisted driveshaft
Old Jun 3, 2006 | 02:48 AM
DictatorDanny's Avatar
DictatorDanny
Twisted driveshaft
Had to try a burn out with my 94 F150 Ext cab 9 inch lift 38`s 302 E40d 4.56 gears. Put her in 4 low held the brakes and gave it the berrys. Well she did a burn out for about a foot then I herd a snap and I see somefly out from the back. Look back see half of my rear driveshaft laying in the road. Well thats all said and done here is the problem I found a driveshaft out of 94 longbox that fit but I think it a little short becaue the slip yoke seems to stick out more than the other driveshaft I know the lift dosent help but I was wondering if longbox has smae lenght driveshaft as a Ext cab. Was also wondering were I could get a driveshaft adapter to lengthing it by putting a plate between driveshaft and rearend. Thanks
Old Jun 3, 2006 | 08:45 AM
depotops's Avatar
depotops
Nope. The driveshafts are off by a few inches. You can't use it on the extended cab. Not sure about the other part maybe someone else knows where to get.
