Thermostat - Need quick answer PLEASE!
Old Jun 2, 2006 | 01:38 PM
crawdad's Avatar
crawdad
Boy, I feel silly asking this question, but which end of the thermostat goes toward the engine? Is it the spring end or the other end that goes toward the engine? I'm getting a bad water leak from underneath the thermostat housing and the only thing I can figure what's wrong is that the thermostat might be turned around. I put a new gasket on. Any other ideas? Truck is in my signature. Thanks guys.
Old Jun 2, 2006 | 02:17 PM
l-m tech's Avatar
l-m tech
the spring goes toward the inside of the intake
Old Jun 2, 2006 | 02:47 PM
hotstang's Avatar
hotstang
One more thing to check
I-m tech is right about the spring going toward the engine. Make sure it is centered in the thermostat housing goove. I had one slide out of the groove and didn't allow the housing to sit flat on the intake and caused a leak. I ended up RTVing the T-stat in the housing to keep it in place and then installing the housing to the intake.
Old Jun 2, 2006 | 02:54 PM
Bob Ayers's Avatar
Bob Ayers
I agree! It is also possible to crack the housing if you try to tighten it down with the thermostat positioned wrong.....
Old Jun 2, 2006 | 03:34 PM
crawdad's Avatar
crawdad
Thanks for the quick help fellas. As it turned out, it was the housing itself. Somehow it had warped (it's aluminum). I placed a straight edge across the housing and you could see the high and low spots. I bought a new housing from advance and that solved the problem. "Spring to engine", I've got to write that down in my manual so that I want forget it again.
Old Jun 2, 2006 | 05:12 PM
mikeyswood's Avatar
mikeyswood
There should also be an arrow on the side of a tstat that tells you the direction. I went through three crappy cast parts store housings before I was able to torque one to spec.
Gasket sealer works wonders when changing the tstat.
Mike
