hi, i've had my f350 for about 5 months now and love her but... the emergency brake spring popped off as i was pushing on it a couple of days ago and i can't figure out how that dam thing goes back on. The spring just fell off and landed on my foot. the pedal still goes down but doesn't engage the brake. I have a manual so i really need the brake. Can anyone tell me if the spring is broke and if not, how to get it back on? I've enclose a picture of the spring. Thanks
If you bought your truck used, the emergency brake may be out of adjustment (Mine was and would barely hold the truck still). The emergency/parking brake is a little drum brake inside of the hub. If you have ever adjusted rear drum brakes, then adjusting the parking drums is EXACTLY the same.
just to be clear - the spring came off the e-brake pedal inside the cab.
thanks
I know. I took a picture for you of the spring in place (You can't see the whole spring without taking things apart) and put the picture in my gallery.
For $60, it might not be worth it to fix - your call though.
Mine did the same thing. I just unbolted the whole assembly from the sidewall and repaired it on my workbench. Regretably I can't remember any details on how to fix the problem other than it was a bitch rewinding the big coil spring. The repair was obvious to me once I had it on the bench. The repair has been working great for at least a couple years now.
