Preditor and Edge Together
Old Jun 2, 2006 | 08:52 AM
Excursionator's Avatar
Excursionator
Greetings all - long time reader, first time poster.
I have an 2004 6.0 Excursion with Banks exhaust, Airaid intake, EGT and Boost guages. I origionally installed a Predator perfromance module that connects between the ICP sensor and was very happy with the product. Then - for whatever reason - I had an Edge w/ Juice module installed. I turned off the Predator when running the Edge (on level 3 - Driving) and after 3 months I don't think it was as good (both performance and milage) as the Predator. So I have turned the Edge back to "0" (stock) and turned the Predator back on.
Just wondering if anyone else had a similar oppertunity to compare both products and.....what would happen if I turned both "on" at the same time?
Thanks for your time.
Old Jun 4, 2006 | 02:07 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
On some chips and tuners you could do what's called "stacking". You basically stack one program onto another. You can try that, but I'm not quite sure if it'll work or not.
