Where's the IDM
Old Jun 1, 2006 | 06:58 PM
Poohbear's Avatar
Poohbear
Where's the IDM
Just wondering where the IDM Is on a 2001 F250 and would it be the same as one on a 97 model. THANKS.
Old Jun 1, 2006 | 07:02 PM
Fat Diesel's Avatar
Fat Diesel
Not sure on interchangability, but it's located under the drivers side fender well. There is a big harness coming out of it and going over the drivers side valve cover. If you are having problems, look at this harness- it has a tendency to rub on the valve cover and ground out there. There are a lot of IDM's on ebay I think because people get an IDM code and think thats the problem.
Old Jun 1, 2006 | 07:28 PM
empiretc's Avatar
empiretc
they are interchangeable
Old Jun 1, 2006 | 08:13 PM
Poohbear's Avatar
Poohbear
I found one beside the emergency brake inside the cab with a harness on the other side of firewall is this it
Old Jun 1, 2006 | 09:00 PM
jtharvey's Avatar
jtharvey
No, that is your ECM. If you were to install a chip, that's the box you'd be looking for. To get to the IDM, you actually have to remove the inner fender well lining. There should be a few fasteners holding it on, that you can get to - you just have to squeeze yourself between the tire and the fender.
