Brake booster?
Old Jun 1, 2006 | 10:03 AM
wintremute's Avatar
wintremute
Brake booster?
I notced over the last few days that when I was at a stop light my brakes seemed to ease themselves off after a minute or two. Yesterday I suddenly have no power brakes. The pedal goes 3/4 of the way to the floor and then I have what feels like manual brakes from there.
Is this a bad brake booster?
Old Jun 1, 2006 | 10:27 AM
NeilK's Avatar
NeilK
sounds like it,,,is your truck idling different, usually will have a hard time idling with a vacuum leak there....
Old Jun 1, 2006 | 10:40 AM
wintremute's Avatar
wintremute
Yes, I've noticed a rougher idle and the rpms seem to drop alot when i go from park to drive.
Old Jun 1, 2006 | 11:02 AM
73Custom's Avatar
73Custom
When it's idling rough, take some pliers and pinch off the vacuum line to the booster. IF the motor smooths out, you know that's leaking.
Marty
Old Jun 1, 2006 | 12:29 PM
Mil1ion's Avatar
Mil1ion
There is a brake booster test, It involves the engine being shut off and apply the brakes then with your foot on the pedal start the engine.
Send me an e-mail for the actual instruction.
Otherwise What I think it is .....the Master cylinder going south
Old Jun 1, 2006 | 12:30 PM
wintremute's Avatar
wintremute
Maybe this is a good time for the F350 brake upgrade. I'll check the vaccum this afternoon.
fasthauler's Avatar
fasthauler
I don't know what size engine you have, but if it is leaking you had better fix it fast. My 460 started leaking and I just let it go for a couple of months. It turns out that the cold air from the leaking booster was going right to the #7 cylinder. This warped the intake valve on the #7 cylinder. It is no fun getting that 80 pound plus intake manifold and the equally heavy head off to get the valve replaced.
Old Jun 1, 2006 | 12:36 PM
wintremute's Avatar
wintremute
It's a 302. The master cylinder is less that a year old, but the P.O. did it and I don't know what quality of part he used.
Mil1ion, msg on the way.
Old Jun 1, 2006 | 12:54 PM
Mil1ion's Avatar
Mil1ion
There have been a LOT of go faulty Master cylinders these last few years.
The don't build them like they used to.
Get one with a stainless steel sleeve.
Old Jun 1, 2006 | 01:01 PM
fasthauler's Avatar
fasthauler
Hey Dennis, I fought rebuilt master cylinders for a lot of years, so it is nothing new. I found out a couple of years ago that a new master cylinder is only about 30 percent more so I opted out for a new one on my 77 and haven't had a problem since.
Gary
Old Jun 1, 2006 | 07:43 PM
wintremute's Avatar
wintremute
ok, so I pumped the pedal a couple of times, started it while pushing on the brake and the pedal did drop down.
If I press the pedal repeatedly, it sputters and wants to die. If I hold the pedal, the idle drops slightly.
I clamped off the vacuum to the booster with vice grips, then released them and it stumbled then recovered.
So is this indicative of a bad booster or MC? I'm still leaning toward the booster.
Old Jun 1, 2006 | 08:09 PM
Mil1ion's Avatar
Mil1ion
Can anyone read this ?
EDIT:
Photo can't be read.
E-mail on the way WM.
The MC is a hyraulic not related to vacuum.
This is why their are different tests
Old Jun 2, 2006 | 05:47 AM
wintremute's Avatar
wintremute
Thanks Dennis, I will test it out this afternoon. BTW, I have already checked the whole system and there are no leaks an no apparent loss of fluid in the MC. The wheel cylinders appear to have been changed at the same time as the MC by the PO.
Old Jun 2, 2006 | 09:14 AM
Mil1ion's Avatar
Mil1ion
In this case of a faulty MC.....the fluid doesn't leak out of the system.
It leaks passed the piston seals from the line back into the master cylinder
This action causes the pedal to drop....the vehcile to start rolling as there is no resistance from hydraulic pressure... to keep the pedal up where it should be.
Old Jun 2, 2006 | 09:52 AM
wintremute's Avatar
wintremute
OK I see. If that's the case, would I still have manual brakes at the lower 1/3 of the pedal? It seems that if the seals failed, then I would get no braking at all.
Of course I'm just brainstorming - not trying to be argumentative. I'm at work right now and can't actually test anything.
