code 302 and then 304
Old May 31, 2006 | 12:19 PM
bertExpy's Avatar
bertExpy
Angry code 302 and then 304
hello fordmaniacs
97 ford expedition eb 4x4 133000 miles
last week my truck stared missfiring but i did not get any codes
i took it to the freeway and the cel stared flashing
code 302 (cylinder 2 misfire) went home cleared the code drove for 3 days still misfiring
took it back to the freeway cel light started flashing again this time code 304(cylinder 4 misfire)
is it time to replace the spark plugs or is something else i should check
i bought the truck 3 months ago
thanks
Old May 31, 2006 | 04:37 PM
coldairintake's Avatar
coldairintake
Misfire could be a plug or coil.
My 2 cents...
Replace all the plugs using only motorcraft, these engines do not like anything else. Make sure to use the diode grease on the boots before putting them back on.
If you have never worked on this engine...read this.....
https://www.ford-trucks.com/forums/s...d.php?t=104027
Old Jun 3, 2006 | 05:49 PM
bertExpy's Avatar
bertExpy
i just change my spark plugs and oil/oil filter
and now its running smooth
thank guys
Old Jun 3, 2006 | 08:07 PM
lv2race's Avatar
lv2race
bert, how was the plug change? I want to do my 2000 5.4 Expy.
Old Jun 3, 2006 | 11:29 PM
bertExpy's Avatar
bertExpy
cylinders 1-2-5-6 are okay but 3-4-7-8 are a little pain in the *** specialy 8
you need the 5/8 socket extension one of those connectors that bend another extension any your ratchet and patience a lot of it
be careful with the injectors do not pull them off
