Fuel cooler for regulated return system
Old Jun 6, 2006 | 09:30 PM
  #31
clux's Avatar
clux
Originally Posted by cookie88
IF the supposition that there is more power/better economy to be gained from cooler fuel is correct. Then the only place you could realistically mount the cooler would be up front in the airflow immediately prior to it being fed to the engine.
I thought the primary purpose of the cooler was to keep cooler fuel flowing to the fuel pump, thereby prolonging the pump life. I don't think you are going to significantly change the temperature of the fuel in the head galleries regardless of what you do.
Old Jun 6, 2006 | 10:22 PM
  #32
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
In that case the cooler would need to be mounted directly in front of the pump. But I agree, I do not believe we can make a significant change in the fuel temperature at all. That's why I posted I don't think it's a necessary mod in my first post.
Old Jun 6, 2006 | 10:36 PM
  #33
clux's Avatar
clux
I do not believe that is the case. The objective is to remove the most heat from the fuel. The hottest fuel in the system (outside of the fuel galleries) should be the return fuel.
The coolest fuel in the system should be in the tank.
In which situation will the fuel cooler dissipate the most heat, running the hottest fuel in the system through it, or running the coolest fuel in the system through it?
Old Jun 7, 2006 | 07:52 AM
  #34
Kwikkordead's Avatar
Kwikkordead
Here's another thing to consider if one is serious about adding a fuel cooler: A fully regulated return system has all the fuel flowing through the cylinder heads and returning to the tank.
The stock system returns the fuel to the tank before it get's heated in the heads. Only what the injectors are needing to use is sent to the cylinder heads.
Not to sound haughty or anything, but I'm starting to think that my little oriface bleed off system has some advantages over a full flow regulator system. There's a lot less fuel getting heated up and sent back to the tank.
Red Ford Truck
Ontario Chapter
39
Oct 26, 2012 06:36 PM
ceetwarrior
Aug 12, 2010 02:24 PM
duphofff
16
Jul 27, 2010 02:43 PM
uc4me
Jan 28, 2008 08:26 PM
993/4ton
Washington Chapter
Jun 27, 2007 10:16 AM
