1966 - 1977 Early Broncos
9" rear end
Old May 30, 2006 | 10:35 PM
broncoman66's Avatar
broncoman66
9" rear end
Could someone tell me how wide an EB 9" rear end is, drum to drum?
Old May 30, 2006 | 11:28 PM
fishmanndotcom's Avatar
fishmanndotcom
58" WMS to WMS
-cutts-
Old Jun 4, 2006 | 01:05 AM
69cruiser's Avatar
69cruiser
fishmann would a 9inch from an 79 f 150 be a better swap for an EB got to find something to do with the 9 and the 44 from the f150
Old Jun 4, 2006 | 08:42 AM
monsterbaby's Avatar
monsterbaby
the F150 axles will be much wider than the eb axles so your tires will stick out quit a ways
Old Jun 4, 2006 | 03:28 PM
69cruiser's Avatar
69cruiser
so in other words get the saw saw out and do some trimming i would also have to reweld the perches on both axles
Old Jun 4, 2006 | 03:30 PM
69cruiser's Avatar
69cruiser
the other reason why i wanted to swap them onto th EB is the 44 already has disk brakes
Old Jun 4, 2006 | 07:37 PM
RCrawler's Avatar
RCrawler
The rear perches will need to be moved. On the front, I've heard of guys that have stretched out the radius arms to match the C bushing mounts. The problem with relocating the C mounts on the full size axles is that some of them are cast into the housing.
Jason
Old Jun 4, 2006 | 10:00 PM
1bad73bronco's Avatar
1bad73bronco
A 79 D44 is cast in wedges so you will not be able to cut them off and relocate them.
Old Jun 4, 2006 | 11:22 PM
69cruiser's Avatar
69cruiser
would using extended arms cause any other problems now this EB will just be used to bash in some mud and an ocasianal trip to the sand so i do not care to make it a show truck i just want it to be reliable and a fun truck to bash
