N7ghtwolfs stupid....Ignition problem
Old May 30, 2006 | 10:26 PM
N7ghtwolf's Avatar
N7ghtwolf
So, today I was chaning the plugs in the truck and I tore two of the Wires. I ran to AdvanceAutoParts and picked up some new Autolite wires. Without thinking I took out all the wires without knowing what the firing order is. Now I tired to figure it out and just couldn't and it won't start up. Anyone able to tell me the correct configuration for the firing order for my 300? And also, why did the wire set come with 8 wires when I thought there were just seven comming from the distributor?
Old May 31, 2006 | 12:26 AM
N7ghtwolf's Avatar
N7ghtwolf
Gott get this running by tommorow, can use any help in figuring out.
Thanks in advance,
N7ghtwolf.
Old May 31, 2006 | 12:46 AM
optikal illushun's Avatar
optikal illushun
heh, its just a spare...
good way to remember firing order of all inline 6s...
1-5 (to young) 3-6 (to old...for some) 2-4 (just right...for all!)
umm...i really dont remember dist. rotation...but i wanna say clockwise.
Old May 31, 2006 | 01:00 AM
N7ghtwolf's Avatar
N7ghtwolf
I didn't understand that, i'm still learning!
Old May 31, 2006 | 01:52 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The Firing Order is :
1-5-3-6-2-4
The rotation of the distributor is Clockwise.
There should be a "1" "written" on the distributor cap. That wire, "post" is cylinder one, hook the wire from this post to the number one cylinder. The next pole, clockwise from the number one post, is number 5, hook that to number 5 cylinder. Then the next is number 3, and so on.
The cylinders on the engine itself are numbered, 1 through six, starting from the front, of the engine to the back.
Old May 31, 2006 | 09:39 AM
300I6VAN85's Avatar
300I6VAN85
Talking
Hey Optikal, I like that old school stuff, 15, 36, 24. Another number set that sticks in my mind is 36, 24, 34 and can usually be found on nine's and ten's. Is that true that all I6's fire that way? A way to check firing rotation is to crank the motor over and watch which way the rotor cap spins.
Old May 31, 2006 | 10:34 AM
N7ghtwolf's Avatar
N7ghtwolf
Running. And running much better than before??? Those wires were pretty old, would these new ones have much of an effect on the truck?
Time to go change the oil.
Old May 31, 2006 | 11:44 AM
optikal illushun
im almost positive that all inline 6s fire that way...at least domestic.
yes, old/worn plug wires can make such an improvement that it seems like u stuffed a new engine under the hood.
Old May 31, 2006 | 03:18 PM
300I6VAN85's Avatar
300I6VAN85
Another way to check for bad plug wires is to look under the hood at night, the darker the better.
Old May 31, 2006 | 03:26 PM
81-F-150-Explorer
Fireworks and Christmas tree lights, spring to mind.
Old May 31, 2006 | 05:32 PM
Silver Streak's Avatar
Silver Streak
Yep, they do. Another little known fact is that most v8's fire the cylinders in the same order. The firing orders look different because different manufracturers identify the cylinders differently.
Old Jun 1, 2006 | 10:37 AM
300I6VAN85's Avatar
300I6VAN85
Talking
Firing order red flag! My book must be wrong or the coffee has not kicked in. But the book has listed for the v8-302 1-5-4-2-6-3-7-8, with the rotation of COUNTERCLOCKWISE. The v8 351 and 400 fire 1-3-7-2-6-5-4-8 CC and the desmell v8 420 and 444 injection order 1-2-7-3-4-5-6-8, no rotation listed. The book I am looking at is Chilton's Ford full size vans 1961-88 repair manual, page 2-6. Have a good day, and keep your eyes peeled for curve ***** and slidders. Come on coffee, day lights a burnin.....
Old Jun 1, 2006 | 02:44 PM
81-F-150-Explorer
No, all that is correct.
Also 302 V8s built after 1994 have a firing order of 1-3-7-2-6-5-4-8, and is also counter-clockwise. Before 1995 the firing order is, 1-5-4-2-6-3-7-8.
Can get quite confusing.
As I said in the above post. 300 I6s firing order is 1-5-3-6-2-4, rotation. Clockwise.
Old Jun 1, 2006 | 02:47 PM
optikal illushun
didnt the 94+ 302 take after the 351s firing order?
Old Jun 1, 2006 | 02:53 PM
81-F-150-Explorer
My book says 1995+
