Sponsored by: Real Truck
Broken Tail Gate handle
Old May 30, 2006 | 10:10 AM
AMC1966's Avatar
AMC1966
Anybody know how to open the tailgate when the handle breaks? I have tried to remove srew on the inside to get at the mechanism with no results.
Old May 30, 2006 | 11:32 AM
AMC1966's Avatar
AMC1966
Ok more description. 1999 f 350 tailgate. You lift the handle and the mechanism does not release the gate. It is not locked. Is there anyway to drop the gate and then acess the inside to repair?
Old May 30, 2006 | 12:56 PM
Dave S's Avatar
Dave S
I know this sounds dumb, but my damn tailgate has done that since new. You just gotta break out the key and unlock it again. It's a roya PITA, but the dealership here isn't the best.
Old May 30, 2006 | 03:00 PM
ryaneverk2's Avatar
ryaneverk2
If you lower the tailgate there are about 8 screws on the inside of it (facing the cab when the gate is shut) that need to be removed so you can remove the access panel and access the inside of the tailgate. I'm not sure if you'll be able to remove them with the gate stuck in the closed position, but I think so.
Old May 30, 2006 | 03:37 PM
AMC1966's Avatar
AMC1966
Thank you for the response. I removed 4 screws and attempted to pry the inside plate off but it looked like it was fastened around the side of the gate that is not accessable. I am going back out to remove all 8 screws and see what happens.
Old May 30, 2006 | 03:52 PM
AMC1966's Avatar
AMC1966
Dave S Thank you for the suggestion! I tried to lock and unlock and on the fourth time it unlocked and opened. Glad I did not scrape all the bedliner off to get at the screws. Thank you again.
