cutting cab corners out
Old May 29, 2006 | 09:04 PM
F100man's Avatar
F100man
What is the prefered method of measuring or marking to cut for new cab corner patch? Bought corners from Early Ford
Old May 29, 2006 | 10:04 PM
Randy Jack's Avatar
Randy Jack
Which corner?
I haven't used prefab patches yet. I usually make my own. However, in a complicated shape area, I usually rough shape the patch to the area to cover, then use it as a template to mark the area to cut out. I then size the patch and cutout together (depending on which one is easier to size) so that I get about a .040 gap all around. Then I use magnets to hold it for the initial tacks.
Old May 30, 2006 | 04:10 PM
jaye's Avatar
jaye
Last week on Trucks they just cut out the rusted area about an inch past the rust then use the piece that they cut out to make a template on the new cab corner, cut it then fitted it in. They used this glue that costa bout $80 bucks a tube whis is suppose to be as tough as welding with the posibility of warping. It came our pretty good.
Jaye
