315's/SPEEDING!!!!!
Cop jumped the interstate and was following us, has the cruise set on 75mph (speed limit of Colorado). Stayed on us, finally pulled us over. CLOCKED AT 86!!! Explained it, but the jerk-off still gave us a ticket. I expected it to run 2,3,4 mph fast, but 11mph????
Seriously though, the truck needs a pretty accurate speed signal for a few of it's modules (PCM, Tranny, ABS) to work right. Your local dealer can probably re-program your PCM for just a few bucks.
You screwed up. Pay the ticket, do defensive driving, whatever. Quit whining, quit insulting the officer by calling him childish names, etc. In short, deal with it.
Oh, and get your PCM recalibrated. It'll save you more tickets and keep you from burning anything up on your truck.
I had 295's on my 2003 and got bagged exactly the same way - 78 in a 55 - I sucked it up and admitted I made a mistake - AND WAS LET LOOSE - but it wasn't expected and I thanked my luck because I was wrong - I never once looked to blame someone else for my lack of judgement - I messed up, simple as that.
You can disagree, and I found the original post amusing because it hits close to home, but if you really want to get down to it most times when assigning blame, a simple look in the mirror will suffice - for me as well as anyone
At least this is what I know from having my truck "calibrated" after installing 325/70r17 tires on my 06 F250. I watched the tech go through the PCM calibration and put in the correct size, but as soon as I left the dealer and drove a few miles, my GPS showed me about 5 mph off. I'm used to it now, and if I got a ticket because my speedo was off, its not the cop's fault.
I just put aome take off 265/65R18s on for a long trip and my speedo was back to almost dead on.
I think we all know what happens when one "assumes". In your case, it holds true. You insult me for posting the results of changing tires, and then doubt the veracity of the fact that it raised the speed 11mph?? You "assume" we were driving 79......we were going 75 on cruise. Cop registered 86mph. Did I imply I wasn't going to pay the ticket/reconcile the action?? You imply that I am a liar, but want me to not call an officer (which you didn't meet) a childish name. Laughable. I am sorry to the readers that tvs has had to detract from the original intent of my post.
VZE,
.....No, I wouldn't consider the officer a hero if he helped my wife and daughter if they were stranded on the interstate. I'd consider him a guy that is doing his job. Personally, I don't get much into the cop/hero worship business. They have chosen a line of work that pays well for someone who most likely doesn't have a college education, can retire in 20yrs with a pension, gets freebies everywhere they go, can live in certain apartments for free, and is probably funner/more interesting than 99% of jobs out there. Sure, there is an element of danger to the job, but so is installing shingles. And a roofer makes the choice to put his life on the line just the same............I feel I am going to insult some law enforcemnt professionals, and I am sorry if that is the case. Not my intent. But I feel I have the right to refer to a police officer as a jerkoff without it being as serious of an offense as spitting on the Pope's ring.
OFF RANT--Point is, 315's WILL change your speed! Only thing I wanted to impart!!
1. Tire sizes (the size listed on the sidewall) are an estimate, not a measurement.
2. Several things can effect tire size, air-pressure, load, and wear.
3. When the dealer re-programs for larger tires they often use the tires listed size, not it's actual RPM.
4. The accuracy of the speedo from the factory is often off from the get go, so adding larger tires may make the problem that much worse. It seems like whoever does the program for the PCM put in an average for all the possible tire sizes and that's what the truck comes with. When I tested my speedo with a GPS and stock tires it was off by -4 mph. at 70 mph. So when the speedo read 70 mph I was actually doing 74 mph.
So it's important that if you have the dealer re-program your PCM that you know the tires RPM at freeway speed, with a normal load, and proper air-pressure. And then have them use the RPM and not a stock size listed in the diagnostic tool.
It's also important to note that the PCM is limited to RPM's of 600 or greater, or about a 35" tire. Go bigger or use a 35" tire that is actually larger than 35" and it would probably be best to go with a TruSpeed from Superlift. The TruSpeed takes all of an hour to install and once calibrated can be very accurate. After a lot of tinkering, I was able to get my speedo and odometer within .5% of my GPS using the TruSpeed.
http://www.forddoctorsdts.com/articles/article-05-21.php
