Fuel Pump with no power
Old May 29, 2006 | 05:38 PM
fixnair's Avatar
fixnair
Smile Fuel Pump with no power
I adjusted my fuel pressure up to 100 PSI the other day and now my fuel pump has quit. Went under the truck to troubleshoot and found no power at the pump. I hot wired the pump to get home then I checked the upset switch and it was set. Does this thing have a pressure switch or a relay that could be toast?
"02 F350 7.3 Ltr PowerStoke Diesel
Old May 29, 2006 | 08:25 PM
Franklin2's Avatar
Franklin2
There is a fuse #40 and a fuel pump relay K4 located in the fuse box under the dash.
Old May 30, 2006 | 12:06 AM
fixnair's Avatar
fixnair
Thanks Dave, I will look tomorrow for the relay. I have already checked the fuse which is OK.
