Hey, Fella's it looks pretty good with just a few leafs removed. I've got reverse-eye MLO on the way for the front, should drop another 1 & 3/4. Just need to measure the rubber stop, it's less than two inches from touching. Got more pics in the gallery check them out!
Devan,
Looking good. If you decide to drop the rear a little more you can relocate the front spring hangers on the rear sprgins higher on the frame and get another inch and a half or two inch drop and it doesn't cost anything except some time. Have a gallery that shows how I did mine as I learned from others on the site. Good Luck. Joe
