running rough
Old May 28, 2006 | 05:56 PM
RAHOYT's Avatar
RAHOYT
running rough
Hello, I,m new here so I,ll cut straight to the chase.
I,ve got a 91 f-250 7.3 IDI, automatic that has had zero issues in the last three years. However, in recent days it has begun to idle and run rough. No smoke, except the usual at first start-up after sitting overnight, but it just idles and runs rough. I have replaced the fuel filter and air filter, have run two tanks of diesel kleen through it and have cracked injecter lines one at a time, all seems well. Any ideas as to why this thing is running soo poorly?
Old May 29, 2006 | 03:55 AM
PLC7.3's Avatar
PLC7.3
When you cracked the injectors was there any one that made no difference to the engine operation. If so that would be the/a suspected bad injector.........
Old May 29, 2006 | 05:41 AM
bilder12's Avatar
bilder12
when you crack the injector lines, the fuel should be clear and not frothy (air in the fuel on one or 2 injectors). This would be a sign that the injector is getting weak and allowing compression gasses backwards into the system. Basically, the injector isa one way valve that is opened by injection pressure spraying fuel into the pre cup. The spring gets weak or broken and allows the compression pressure to flow backwards OR a piece of dirt got through the filter and into the injector and has scratched/gawled the injector not letting it close properly OR the injection pump has suffered from the same thing (last place to look). You may also be picking up air in the system from a broken pickup tube, but that might show up as white exhaust smoke.
Old May 29, 2006 | 10:18 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Rahoyt,
Welcome to FTE and the IDI diesel forum.
I can not add more to what the previous posts have said.
Old May 29, 2006 | 11:21 AM
RAHOYT's Avatar
RAHOYT
running rough
I heard change with every injector but I wasn't looking for frothy fuel, I'll have to run them again and let you know. Thanks
